Thread: Ye Olde Rope Float
    Rock Tavern, NY
    Default Ye Olde Rope Float
    Our first rope float was nice - the floats were somehow locked into their respective positions on the rope and never moved around. It had hooks for the eyelets at each end - it was good. When, after years of UV and HTH abuse (before being Born Again to BBB) I finally had to retire it (the rope was disintegrating), I purchased a new one. One end has a hook, the other needs to be tied off in a knot at the opposite wall cleat. The most annoying part is that all the floats are free agents - they flop about and are not "anchored" to the rope. How do I fix this, short of ugly knots on each side of each float? Its petty, true, but it irritates me.
    18x42 Spartan Roman End Vinyl Inground (1981)
    1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
    Morris, IL
    Default Re: Ye Olde Rope Float
    What about a stainless screw and stainless nylon lock nut? Put it through the rope on each side of the float, the nut should hold the float in place and you could get them small enough to be relatively inconspicuous.
    Rock Tavern, NY
    Great idea! I'll try it. Only thing is, the nut will have to be able to accommodate the width of the rope . . . I'll see what they have at Lowes.
    Morris, IL
    The bolt will have to accommodate the width of the rope I think you mean, plus 1/4".
    a more inconspicuous way would be to silicone or goop the floats in place, hold the float at the location you want it, stick the pointed tip of the goop tube between the float and rope - should go in 2 inches, squeeze out some goop while moving tip in circle to get it around rope and not just on one side of rope - do this to both sides of all floats, let cure - done.
    Rock Tavern, NY
    Ooh - that sounds like it may be the ticket, Matt. Thanks to you as well, Sevver.
  1. Restraining Rope
    By KentRock in forum Intex-type Pool Setup & Operations
    Last Post: 07-16-2012, 11:59 PM
  2. Float for a 2 year old
    By jilted in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 08:25 PM
  3. use of main drain with skimmer float
    By byron366 in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2011, 09:45 PM
  4. Why not just use foam rope?
    By cbridges in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-24-2006, 06:55 PM
  5. Safety Rope
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 04-27-2006, 10:54 AM
