Thread: Using bleach
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: Using bleach
    Quote Originally Posted by rayh78
    Update
    I just checked it with the test strips and everything is now reading the highest level. What would cause the CYA to go up on its own?
    I am guessing it is time to drain and replace at least 1/2 the water?
    Test strips just aren't accurate enough, especially if there is a problem. If possible, please take a water sample to pool store and have them test for free chlorine, total chlorine, combined chlorine, CYA, alk, pH, hardness. Until then, we really can't give any reasonable advice. We would also need to know the type of pool, and its volume.
    Most probably, chlorine went to high to nothing because some bug is growing in water. Increased chlorine should do the trick, running filter 24/7 is critical also. However, without accurate water reading, you can only guess. And guessing can get you in more trouble.
    CaryB
    CaryB is right, anything you do now is only a guess. If you are serious about properly taking care of your pool, dump the "guess" strips and get a good drops based test kit. Needless to say, around here we all prefer the PS234 sold here http://www.poolsolutions.com/cart/kits.php however Taylor makes similar kits for a little more money. Be sure you get a FAS-DPD test for chlorine. At the very least, get the $15 Wal-Mart 6-way test kit but beware that it will not test for chlorine above 5ppm.
    Dave
