Re: Solar Panel Question for Above Groud Pool.............
And it *is* south facing, right?
It makes a tremendous difference if the panels are facing the south sun -- mounting the panels northfacing (even if the sun hits them all day long) will not be nearly as effective (optimum tilt is around 30 degrees if I remember right, but you can easily look this up).
