Re: Doh! Foam Party In My Pool!
I had a PB open my pool (before I found this site), he used a bunch of algaecide. My pool was foamy for about two weeks, it did go away all on it's own, now my pool is sparkling with the BBB method.
I don't see any reason you can not swim IF the algaecide caused the foam, as long as your other numbers are withing normal operating range. Someone with more knowledge than me can tell you that for sure though. If the foam is caused by something else I personally wouldn't swim until I got what ever the problem was under control.
Patience, it will clear.
Oh yeah, stop adding things you don't need, like an anti-foaming agent, or more algaecide.
~Dr. Spike
Pool: IG vinyl, heated, fully enclosed (dome)
Shape: Grecian (rectangular)
Size: 20'W x 40'L
Depth: 4' / 8'
Filter: Sand w/DE added
Other: 6' Diving Board
Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
