Results 1 to 5 of 5
Thread: First Test - Help
    Jan 2006
    Atlanta
    Default First Test - Help
    Ok I put 60 drops in for FC/CC test. The sample stayed a bright pink.
    The TC test the sample stayed a medium orange
    PH - 7.0-7.2
    ALK - 0
    CYA - 120
    The water is crystal clear, not a sign of algae.
    16x32 IG vinyl - 19,200 gallons, full sun
    Is it OK to swim in?
    duraleigh Guest
    Default Re: First Test - Help
    Well, if your test method is correct, you've got 30ppm+ of Cl. What have you been testing with prior to the PS234 and how much Cl did it tell you was in your pool?
    Recheck your Alk test methods....I don't think that's correct.
    Have you not been swimming to this point?
    With that VERY high CYA, you're gonna' need to hold your Cl up in the 8-15 range but, if it's 30+ now, it would be helpful to know how it got that high.
    Jan 2006
    Atlanta
    We just re-opened the pool this year. It's been closed for about 4 while we were doing some major remodeling, but I've kept the pump running and continued to fill the chlorinator with 3inch tabs when I remembered.
    I also added water when necessary.
    I'll retest for Alk and let you know.
    Jan 2006
    Atlanta
    Just redid the Alk test. I think I did not add the green.
    Anyway after the green the sample turned a light blue, then it took 17 drops to get it to yellow.
    So I have a 170 Alk reading. What does that mean?
    duraleigh Guest
    Hi, Jim,
    Alk of 170 is a little high but no big deal.
    Your biggest issue, IMHO, is that really high CYA. You can reduce it by draining half your pool and refilling. It would make your pool easier to manage but that's your call.
    Secondly, you must've been really "slamming" the pucks in there to get your Cl that high. I would suggest that you not use pucks EVER for the rest of the Summer. Your chlorine will need to be provided by bleach. Keep your Cl level in that 8-15 range I mentioned and you should be okay.
    Swim whenever you like.
    When you get a little more comfortable managing and testing your water, read the sticky on how to lower alkalinity in that forum.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
