Closed Thread
Results 1 to 8 of 8
Thread: galvanized steel vs. stainless steel
    Jul 2006
    Default Re: galvanized steel vs. stainless steel
    Thanks. The booklet says
    "Pools are constructed using heavy gauge steel covered with twice as much protective coating as commercial grades (G-235)." Is this the grade steel being used?
    Quote Originally Posted by Sean-NJ
    G-235 is the weight of the zinc rich coating that is applied during the galvanizing process. It is about the best IMHO. Just to compare, it is the specification that most State DOT's spec for the light post and interstate signs you see. I would go with it and forget the stainless.
    Dave
    Jul 2006
    Thanks Dave!!
    What about the aluminum walls that I have seen some places sale?
    Quote Originally Posted by thewayne
    Aluminum does not rust, is stronger than steel by weight so it will have to have slightly thicker walls to achieve the same strength as its steel counterpart but would be lighter in the end. It is more expensive pound for pound than steel. It will still corrode from salts, chemicals (chlorine) and stray electrical currents. In my limited experience while shopping around, I never saw aluminum as an option for an inground pool. I still think galvanized would be the way to go.
    Dave
Closed Thread
