Quote Originally Posted by Sean-NJ
Thanks. The booklet says
"Pools are constructed using heavy gauge steel covered with twice as much protective coating as commercial grades (G-235)." Is this the grade steel being used?
G-235 is the weight of the zinc rich coating that is applied during the galvanizing process. It is about the best IMHO. Just to compare, it is the specification that most State DOT's spec for the light post and interstate signs you see. I would go with it and forget the stainless.
Dave
