It's not a stupid question. There should be no CYA in your tap water, ever. There is no good reason for any municipal water utility district to add CYA and in fact CYA is dangerous if ingested in large quantities so it's not something that anyone would put into drinking water (and yes, this means you should not drink your pool water, except in an emergency).Originally Posted by court475
The main components to test for your tap water would be alkalinity (which will be completely carbonate alkalinity since there is no CYA) and calcium hardness. pH would be interesting, but that could change by the time your pool gets filled and is probably near neutral anyway so primarily focus on figuring out how much calcium you need to add (as Calcium Chloride) and alkalinity (as sodium bicarbonate aka bicarbonate of soda). Adding these two items to neutral water will result in a pH near 8.0 at which point you'll need to add acid to get down to the pH you want (probably near 7.4-7.5).
If you want to be totally safe (and this is probably overkill) you can add the calcium chloride and sodium bicarbonate in portions as your pool gets filled. However, I noticed that our own pool got filled first and then had chemicals added and didn't have a problem even though technically the plaster and grout was dissolving (albeit slowly) into the water between the time it was getting filled and the extra chemicals were added.
Richard
