Thread: Electrolysis to remove iron from pool walls
    Dec 2005
    Honolulu, Hawaii.
    Default Electrolysis to remove iron from pool walls
    Does anyone think this might method help to remove ferric oxide/rust from the pool walls. Please see method at this site;
    http://www.chip.com/buick/techtips/rustremoval.html
    Or am I crazy!
    Aloha,
    Paul
    mas985's Avatar
    Pleasanton, CA
    Default
    Electrolysis only works if the material you are removing the rust from is conductive (i.e. a metal). So it could work for metal pools.
    Mark
    mbar's Avatar
    Ashland, PA
    Default
    I read something about staining on fiberglass pools, I copied the Paragraph:
    "Fiberglass has a negative electrical charge and can attract positively charged metallic ions, causing the development of a stain. The periodic addition of a metal treatment should help negate this effect and help keep pool stain free. "
    It would explain why fiberglass pools stain more easily than other pools, and why I can't figure out where the stains in my pool come from. I will try to find out more about this too --and if anyone else knows anything please help!
    Northeast PA
