Re: Converting with DE filter problem
Hi,
When I did my conversion a few yaers ago with a DE filter I ended up taking the filter apart and cleaning it every day for the first couple of days. It was so bad that I could not leave the filter on over night because it would plug so quickly. Be assured that after a couple of days it will not be so bad. While I was using baq I would use 50 to 100 lbs of de a year. Now I use less than 12 lbs a year. and that is because I like to clean the filter every now and then. I could probably just let it go and would have no problem. Stay the course and you will be fine. Change the de often at first baq really gums it up.
Ken
