Results 1 to 10 of 20
Thread: Another shock question
    Default
    Quote Originally Posted by alapool
    Will it cause hair to become "straw-like"?
    Thanks a bunch for your answers!
    Having held both Barber and Cosmetologist licenses in the state of Florida for 29 years and having taught both professions I can tell you that it is NOT chlorine (at normal and even shock levels) that causes hair to become "straw like' but exposure to the UV rays of the sun. (You can sit by your pool and never go in the water and it will happen just as fast) Also chlorine will NOT cause the hair to turn green. That is from copper and I have outlined a safe and effective way to deal with that problem in another post
    http://www.poolforum.com/pf2/showthread.php?t=326
  1. Shock question?
    By jmy2469 in forum Dealing with Algae & Slime
    Last Post: 04-22-2012, 07:27 PM
  2. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  3. Algae/shock question....
    By court475 in forum Dealing with Algae & Slime
    Last Post: 09-06-2009, 11:32 PM
  4. Shock Question
    By hannadock in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-30-2008, 05:06 PM
  5. Clorine vs shock question
    By Jebby27 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2006, 08:59 PM
