Closed Thread
Results 1 to 10 of 12
Thread: Salt water chlorine generator research
    Morris, IL
    Default Re: Salt water chlorine generator research
    Do they sence flow like the heater? Or would I wire it in to the switched outlet that the pump is tied into?
    Ft Lauderdale, Fl
    It is required to have a flow protection device. You should wire it on a switched line (actually called the load side). In fact, you should wire it to the same relay that the pump is controlled by, on the same terminals!
    Sean Assam
    Morris, IL
    My pump is connected to an outlet that I have switched with an outdoor switch. I was thinking of connecting it to that outlet, then when I turn the pump on the SWG will also go on, right?
    Ft Lauderdale, Fl
    I believe you're saying that you're thinking of connecting it directly to the outdoor switch, instead of the outlet, right? If you connect it to the outlet, it will be powered all the time. If you connect it to the switch, it will only get energized with the outdoor switch is flipped on.
    Sean Assam
    Morris, IL
    I have an outlet at the pump area that the pump is plugged into, this outlet only recieves power when I switch it on. There is a switch directly on top of the outlet in a separate box. I ran a wire to the outlet box, and the hot one I pulled through the box and connected it to the switch, from the switch I went back down to the outlet box and connected it to the outlet. The other wire I have connected to the outlet. If you think about it, it is the same as wiring a light, except I used an outlet. So I could power it from the same outlet that the pump is on and it would thus recieve power only when the pump had power, ie. when the switch is on.
    kind of like what i have for my pump right now...my pump was wired to a wall switch in my pool shed. i wanted to put in a timer before i get the autopilot SWG. so, i wired the power that went to the pump wall switch to the timer, the load out on the timer goes to the wall switch now to the pump so i have the option to turn off the pump without shutting the switch off in the timer. (convenient if i need to turn off the pump for a minute during timer cycle to clean the basket, switch my filter multiport valve from filter to backwash, etc). the SWG will be fed off the same "line in/load out" circuits as the pool pump. only thing i plan different for it then the pump is that the SWG will not be wired to the "2nd" on/off switch. i know it's not advised to rely completely on the flow valves on the SWG's to shut them off if the pump is off, but the rare time i'll use the wall switch to turn off the pump rather than the timer switch, i'm in the shed anyway and could turn off the timer switch so everything is killed , if i needed to.
Closed Thread
