Re: Cloudy water on Clear Comfort
If they are willing to drain and help you start refill, that's a good idea. So is changing the sand in the filter. Flushing pipes would not be necessary.
By far, the best money you will spend is to order Ben's test kit NOW if you're planning on this. You will then be speaking the same language as the rest of us and your test results will be accurate.....important items in keeping your pool clear for years to come.
