Page 4 of 7 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 69
Thread: CYA for Salt Chlorinator Pools II
  1. #31
    Ft Lauderdale, Fl
    Default Re: CYA for Salt Chlorinator Pools...
    Richard,
    I can tell you from personal experience, I was the R & D director for AutoPilot at one time, that the concentration of chlorine within the cell is WAY in excess of 10 ppm. It was more along the line of 80 ppm, as determined by MANY dilutions of the water sample directly from BETWEEN the electrodes.
    Remember, chlorine gas is produces with quickly gets absorbed by the water yielding a purer sodium hypochlorite. This certainly is sufficient to treat the water at a shock dose, regardless of the flow rate through the cell. However, we've found that by slowing down the water flow, you allow more "contact time" to process the water and rid the combined chlorines, and kill the "bad stuff". Basically, it increases the efficiency of the electrolytic process and killing effect.
    Sorry I'm not a chemist to be able to present ionic formulas and osmosis reactions, but being a very hands on manager at AutoPilot, I've seen, repaired and resolved many salt generator issues as well as pool water chemistry related issues (with and without salt sytems). I'm no expert by any means, but I do have experience and a little (dangerous) knowledge to get by.
    Sean Assam
  2. #32
    Sean,
    I wasn't clear with the amount of chlorine levels in the generator. I was talking about the normal operation that generates the incremental chlorine for the pool and referring to what some people were claiming was a natural superchlorination in the cell during this process. I was also referring to the entire cross-section of area that the water flows through and not just an area near the plates (which has incredibly high concentration of chlorine).
    I believe what you are talking about is a superchlorination mode which runs the cell at a much higher power level. If you ran at this level during the duration of one pool turnover, then the pool itself would get to that 10 ppm level. Is this what you are talking about? I apologize for my ignorance about the mode you have for your cells.
    Richard
  3. #33
    Ft Lauderdale, Fl
    No apologies, but thanks for "slappin me in the face" and making me aware that I sounded like a sales guy. That's the last thing I want to sound like here as it irritates Ben if I do.
    The normal operation, when you inspect anyone's cell, is for the water to pass through and around the electrodes, or blades. Let's face it, the chlorine is only produced between the blades so the space around them does not get the same concentration of chlorine. However, it is quite high between the blades AND still quite high surrounding the blades too. Oddly, if you test the water coming out of the cell, you're prone to only get 1-5 ppm higher than what's tested in the body of the pool. You may see a similar result if you take a water sample from the closest return line to the pool equipment.
    Now, the design of the cell is going to be rather different from manufacturer to manufacturer. If you inspect the various designs, you'll see different dimensions of blades, spacing between the blades, solid vs mesh, % ruthenium oxide coatings on the blades, and power (milliamps/sq cm) to the blades. So when you asked for more details, it's not easy...besides, most of this is proprietary information.
    What I am taking about is not just under superchlorination mode, this is under normal operation. Besides, most Superchlorination mode does not increase the power to the cell, it simply extends the time the cell is energized. I believe there is only one manufacturer that claims to increase the output to 125%.
    Most manufacturers cycle their cells on and off, during the day. Some run the cell continually, for a % of the pump run cycle (I'm not sure how this is determined without having to enter your physical pump run time). Some constantly energize the cell and fluctuate the power to the cell between a low output, up to a high output. Perhaps this last one is the model you're describing? Those are typical of Australian systems that also require higher salt levels to operate (4000 - 6000 ppm).
    Hope this helps
    Sean Assam
  4. #34
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    I've been fascinated by this discussion and I'm continually trying to understand.
    Are you saying that because the water "between the blades" is 80+ppm chlorine while the water exiting the cell is only 1-2ppm higher than the pool itself that the high CYA acts as a transport of that high chlorine? Sort of a way to get it into the pool?
    That logic makes sense to me.....what Doesnt make sense is when Ben's best guess chart comes into play.
    The chlorine in the pool, regardless of where it came from, has the same chemical properties as any other chlorine.
    In my experience, when I ran my SWG at 80ppm CYA, my chlorine maintained at a lower power setting....as suspected. However, Algae on the walls and in the pool ran out of control and I fought it all season.
    Ever since I lowered my CYA to 35-40ppm, I've not had to shock my pool once and haven't had a hint of "slimy walls" or the onset of algae.
    There could be other factors at play since my tests were over the course of 2 seasons...
    Some people have hobbies.....I have a pool.
  5. #35
    Poughquag, New York, USA.
    Yet my results are the exact opposite of Tredge. Running at about 30ppm CYA, I just couldn't keep my 30K IG pool "stable" (Aquarite). Every time I had any type of high bather load or lots of rain or a New York pollen "storm", the pool would get cloudy.
    Now I am running at about 60 ppm CYA (I wonder if anyone can read the test more accurately than a 10ppm swing) and I have been able to scale back the SWG from 60 to 50 to now running at 40%. Water is clear and I am at about 4ppm FC. The pool is much more stable, it just stays clear and nice. It is possible that my results come from finally clearing out any residual "gunk" from opening, but I'm inclined to think it is due to running at or close to the SWG instructions.
    Plus, my PH seems rock solid at 7.4/7.6.
  6. #36
    Sean,
    Yes, you've got my point. The fact that some small area of the cell and therefore some small percentage of volume of water going through the cell is exposed to 80 ppm of chlorine is interesting, but doesn't mean that all or even most of the water is exposed to that level except through many, many turnovers of the pool water.
    An analogy with what happens when you add liquid chlorine (or bleach) to the pool might be helpful. Someone else [EDIT](let's give credit to waste where credit is due)[END-EDIT] mentioned this in this or another thread, but I'll describe the situation a little more deeply. When you add 6% bleach to your pool, you are adding chlorine in a concentration of 60,000 ppm. As the chlorine diffuses into the pool, at some point you will have the chlorine diffused into 1% of the total pool volume at which point the averge chlorine concentration in this volume of the pool will be 100 ppm assuming you added enough chlorine to raise the entire pool's chlorine level by 1 ppm. At a later point in time when the chlorine has mixed with 10% of the total pool volume, this volume has on average 10 ppm, etc. Now of course I'm oversimplifying since the mixing is not uniform (though I used the term "average" which covers up many sins) and there is not an absolute line of demarcation between pool water that has mixed with the chlorine vs. pool water that has not. But the principle is very much the same as what happens in the cell. Though some small amount of water is exposed to very high chlorine levels, it's still a small amount of total pool volume.
    As an aside, the above "analysis" (and I use that term loosely since I was not at all precise in the above discussion) implies that it may be better to add liquid chlorine (or bleach) to the pool in a way that mixes rather quickly with a large volume of the pool water, but not with all of the pool water at once (which is impossible to do anyway). So adding the chlorine over a jet or into the skimmer may be better then putting it into one place in "calmer" water. I'm not sure how distributing it manually around the pool's entire edge would do, but personally I don't like to take that risk of splashing the 60,000 ppm chlorine onto my clothes!
    Anyway, the bottom line is that I think that marketing a salt cell as somehow super-zapping your pool's water by using the high chlorine measurement example is telling the truth, but not the whole truth (I'm not accusing you -- you have been very forthright and honest in your discussions -- I'm talking about sales folks less knowledgeable than yourself). Unless there is good science to explain otherwise, what the salt cell does is not much different from what happens when you add liquid chlorine to your pool except that the cell is doing so continually over a longer period of time. It is possible that this is more optimal in producing the 10% volume / 10 ppm mix through the pool water. It is also true that the chlorine that is initially produced by the salt cell is unbound by CYA and therefore the true disinfecting chlorine concentration may be much higher, though the exposure time before this gets combined with CYA is rather short. Though the same thing occurs with liquid chlorine put into the pool, again the rapid nature of dumping chlorine in the pool is probably less optimal than the continous process of the salt cell.
    Richard
    Last edited by chem geek; 07-24-2006 at 10:03 PM. Reason: added credit to "waste" -- sorry for missing that the first time
  7. #37
    Quote Originally Posted by Tredge
    I don't believe the purpose of the high CYA is to "transport" the chlorine into the pool, but you are close to what I do believe is the purpose of the high CYA in making the salt cell more efficient. I'm going to try to explain this non-technically, but if I fail I apologize in advance.
    The efficiency of the salt cell in generating chlorine is dependent on how much of this generated chlorine already exists near the generating plates. If there is already a lot of chlorine close to the plates that generate chlorine (due to its building up and not getting swept away fast enough), then the efficiency of the process drops and less chlorine is generated. The purpose of the CYA seems to be to combine with the chlorine that is generated and effectively "hide" this chlorine from the salt cell so that as far as the salt cell is concerned, the concentration of chlorine near its plates is not 80 ppm but something much less. The key to making this work is that the chemical reaction that combines the chlorine with the CYA to "hide" the chlorine needs to be faster than the production of the chlorine from the salt cell and it turns out that the critical point where this takes place is around the 60 ppm or so of CYA that is the minimum recommended by the manufacterer of the salt cell.
    Your experience with algae is consistent with what I was saying in my earlier posts that Ben's chart is important to follow because the concentration of the disinfecting form of chlorine needs to be high enough throughout the pool, not just in pool water that passes through a salt cell. On the other hand, many people have reported no algae problems at higher CYA and Sean's experience is that those with lower CYA have had algae problems while those with high CYA have not, but that might have been due to the low-CYA cases having such low efficiency of salt cell chlorine generation that they couldn't produce enough FC to kill algae even at the lower level of CYA. At this point, I would say the jury is still out and my guess is that the continual dosing of chlorine from the salt cell is somewhat more efficient and does probably zap more bugs, oxidize more organics, and kill more *free-floating* algae than the manual dosing of liquid chlorine. That said, your experience shows that this greater efficiency of continual dosing from a salt cell is not enough and that you still need to have "Ben's chart" chlorine levels throughout your pool.
    I do believe that it would be in the best interests of pool owners if the manufacturers of salt cells would at least consider the possibility that designing salt cells to operate at lower levels of CYA would be beneficial to "the rest of the pool" including pool surfaces where algae can develop (and bacteria can hang out in biofilms). All the salt cell makers have to do is simply increase the area of their plates over a larger volume and drop the power so that the local chlorine generation rates are lower since that will require a lower concentration of CYA to be able to "keep up" and "hide" the chlorine that is produced. And yes, this means that the salt cell may have to be bigger or, most likely, longer than it is today and that means more bulk and more piping to deal with this, but if it means a better situation for pool owners, then that's the right thing to do.
    I just want to thank all of you that post on this and other threads. I have never experienced such a wealth and diversity of information and assitance in an environment that has remained civil. It's refreshing!
    Richard
  8. #38
    Richard & Poolsean,
    This is so great for those of us on the edge of understanding it all. Its like reading Scientific America - I don't understand most of it but it sure stretches the mind.
    The ONE thing that hasn't been addressed in your analysis, Richard, is the fact (using the term loosely) that almost everyone using a SWG with fairly well balanced water reports CC at 0 all the time. This is not true (I believe) of those that use bleach to maintain normal FC, at some point they will get a buildup of CC and have to shock (which is another interesting thread you are involved in!). This would seem to support the idea that the SWG is "super-shocking" in the cell and it must be some larger percentage of the water that passes through the cell than you are calculating.
    In thinking about this though, you did say that it might take a couple of days to "shock" all of the water in the pool, perhaps this is happening and is "good enough" to keep the CC reading at or close to zero. I am wondering why or whether this information is available in Austrailia where they have been using these systems for a lot longer than here (at least for non-commercial pools).
  9. #39
    A P.S. to Sean,
    I seem to recall that the typical settings people are using with the salt chlorine generators is that they are on less than 50% of the time. Is it possible to have them on 100% of the time (when the pump is running), but operating at a much lower power level? Don't the lower power levels operate efficiently even at lower levels of CYA? If that is the case, then the simplest thing for owners of SWG to do would simply be to use the lowest power setting and increase their % on-time accordingly.
    Of course, running at 100% means you have no leeway for the system to increase this if more chlorine is needed (due to increased chlorine demand), but if your system would instead just vary the power as needed (instead of the time) then this approach might work. What do you think?
    Richard
  10. #40
    I wonder if some of the problems that SWG owners have encountered with algae at recommeded CYA levels could be to either:
    1) running at the low end of the recommeded 1-3 ppm FC levels
    2) not keeping a good check on the pH and allowing it to drift upward too much before lowering it?
    I maintain my pool at 3 ppm FC and do not let my pH rise above 7.6 (okay, MAYBE 7.8) before I add acid.
    Also since my SWG does not compensate for temperature (Goldine Aqualogic PS-8) I do ajust my cell output if I see the chlorine levels are dropping or rising. (my pool has run on as low as 5% output in cooler weather up to 15% recently with my FC going up to 4 ppm)
    I do test my water at least weekly (full tests except CYA and CAL) and do OTO and pH testing at least once more duing the week. Perhaps this is the difference in why I have never had any problems with algae. I test a lot of water at the pool store and I see that many owners of SWGs let their pH climb to 8.0 or above and never really get it down to where it needs to be. I also see these people having algae problems in their pools. On the other hand I had several customers with very low CYA (30 ppm and below) that were running their cells at very high output and also had algae problems and cloudy water in their pools. In both cases these people reported back to me that their problems seemed to disappear when their CYA levels and pH were brought into line.
  1. new salt chlorinator system
    By buddy97 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-21-2012, 07:28 PM
  2. Salt chlorinator
    By Jaws2 in forum Pool Equipment & Operations
    Last Post: 04-20-2012, 02:31 AM
  3. Salt Chlorinator Question
    By JohnASmith in forum Pool Equipment & Operations
    Last Post: 09-13-2011, 02:52 PM
  4. CYA for Salt Chlorinator Pools...
    By Karin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 08:13 PM
