Absolutely no offense taken at all. You are correct that I have zero experience with SWG systems, I agree completely with your points, and I'm the one who has to be careful not to offend. My educated guess as to what is going on is not inconsistent with the real-world results and yes, it's the theory that must match the real world, not the other way around.Originally Posted by waterbear
I was just dumbfounded with the initial claim that the salt cell has superchlorinated levels of chlorine AND that this was getting applied to all of the pool water (in a reasonable time).
There is one big difference between UV and ozone sanitizers vs. SWG as far as I understand them and that is that the former do in fact "do their work" on the entire volume of water that flows through their chambers so that after a few hours with one turnover of pool water, the majority (I forget the number and how to calculate it, but I think it's around 70%) of the water in the pool has been sterilized and oxidized at least once. This does not appear to be the case with the SWG and instead some fraction of the water goes through amounts of superchlorination. I could be dead-wrong about how the UV and ozone systems work so if anyone knows if they "slow down" some part of the water in their systems in order to more effectively disinfect and oxidize, please let us know.
Since putting in liquid chlorine (bleach) also superchlorinates a part of the pool water when it is introduced into the pool, then the incremental benefit of the SWG probably derives from its continual dosing which is more optimal. I wonder if people without SWG were to manually dose their pools more frequently (with smaller amounts of chlorine each time) and did so over pool jets at both ends of the pool if they, too, could operate at lower levels of chlorine safely. My guess is that they could, but I have no idea what the required FC level would be between "once a day" well-distributed manual dosing vs. the continual dosing of the SWG.
The 3 ppm FC level that you found to be required for your pool is still very safe from a disinfection point of view since 70 ppm CYA, 7.6 pH and 3 ppm FC gives 0.017 ppm HOCl which is above the 0.011 "minimum" that appears to be needed for disinfection (and that's in non-SWG pools and spas).
Again, I think SWG is great and just because I "bash" a specific claim doesn't mean I think the technology as a whole has no net benefit. On the contrary, I regret not having one installed when we put in our pool (it was not mentioned as an option by our pool contractor and I knew even less about pools then than I do now).
