Re: CYA for Salt Chlorinator Pools II
chem geek
By the way, what is your CH level and pool water temperature? The saturation index I calculate at 80ºF and 300 CH (with 7.3 pH) would be -0.28 (using my newer index, though the old index is -0.30 so about the same in this case). This isn't horrible and may be a very mild corrosive condition (if you have a plaster pool), but if you want to be in balance, then CH would need to be 700 (with my new index; 600 with the old). Of course once you commit to this high a CH, you have to keep your pH and alkalinity at your current low levels unless you drain your pool water to dilute the calcium.
Richard
Langelier Saturation Index is, IMHO, a bogus measurement for pools. It was designed for closed systems and a pool is an open system. See these posts (2 of mine and one from Ben):
http://www.poolforum.com/pf2/showpos...91&postcount=7
http://www.poolforum.com/pf2/showpos...3&postcount=13
http://www.poolforum.com/pf2/showpos...1&postcount=17
