Re: Chlorine tab question
The "tabs" whether 1" or 3" are trichlor. They’re great except
1. They continually add CYA (a.k.a. Stabilizer or Conditioner) to your pool. Too much causes the chlorine to be less effective which means you need more. The only way to get rid of CYA is to drain some of the water to lower the concentration (ppm.) or you can let your pool turn into a swamp for a while and the algae will eat it up. This is actually what usually happens to unsuspecting people when their CYA gets above 100 ppm and they are trying to keep .5 ppm of FC (Free Chlorine).
2. They lower the PH drastically in a typical pool. The tabs ph is around 2. You want your pool to be around 7.5.
3. They give the consumer a false sense of security by leading them to believe that as long as there is a tab in the skimmer, They’re adding chlorine and my pool is sanitized.
These exceptions are the exact reason we use bleach around here. I personally don't see a real dollar saving of bleach compared to the tabs however if you add in the partial draining of the water, all the Borax needed to correct the PH and all of the time it takes to do these I am definitely saving money.
The liquid shock you are speaking of is the same thing as bleach, just in a higher concentration. Look at the labels. Bleach is usually 6% Sodium Hypochlorite and the liquid shock is usually 10% Sodium Hypochlorite. Either one is fine. If your PH is below 7.4, you should probably add Borax. Post a full set of test numbers and we can advise you further.
Dave
P.S. Tabs in the skimmer verses a floater will not change anything
