The jets you read about are spa jets. They send out little bubbles like a hot tub. You obviously don’t have these but that’s OK. You can simply point your return(s) up towards the surface as high as they will go. Also, a bunch of splashing around will help even more. Waterfalls are also a great help if you have one. The idea is to lower your PH and aerate. Any of the above mentioned things will work but you must be patent as it will take at least three attempts to lower your ALK 100+ ppm. This is where P.O.P (Pool Owner Patience) comes into play. I assure you, the sticky you read works. Also, Hulla is right. Muratic, though a little harder to work with, is much more effective and is what I recomend. Get it at Home Depot or Lowes.
Dave
