Results 1 to 10 of 10
Thread: Stains no quite coming out with Vitamin C, maybe not enought POP?
    mbar's Avatar
    Ashland, PA
    Default Re: Stains no quite coming out with Vitamin C, maybe not enought POP?
    Keep the ph low, add some more ascorbic acid - try to add it where the stains are most prevelent - You should be ok with the sequesterer, but if yo have more add another half bottle, more is better than not enough, and it depends on how much staining you had - turn the filter to cirulate for about 2 hours, then back to filter. If you have extra ascorbic acid, it will only filter out - so don't worry about that. Sometimes it's hard to have patience - but you should see all of the stain go away with the intial dose of ascorbic acid, if it didn't that means that there wasn't enough of aa or sequesterer. The only time it's better to wait is if the stain is new - then you take the ph down add sequestering agent and wait to see if they disappear. Welcome to the forum, feel free to ask any other questions you may have.
    Northeast PA
    Jul 2006
    I added some more ascorbic acid, and some more sequesterer. It seems to help, or maybe it is just my eyes. But I get the impression from comments it should be instantaneous.... I'll know better as the sun gets lower, with no shade in the yard, it is just glaring right now and hard to see the bottom of the pool.
    You mention to just circulate, but not filter the water. My plumbing is such that it always runs through the filter. Is this unusual? I have a cartridge filter, so I guess I could take the filters out??
    I'll keep it running, and see how it goes.
    Thanks for your help.
    David.
    IMHO, 1 lb of ascorbic acid will treat 10000 gal...therefore you needed 1.5 lbs initially. Most of the metal sequesterants I have seen also treat 10000 gal with 32 oz so you would have needed 1.5 qts. initially.
    Depending on the stain it might take a few days of filtering to remove all of it. If your water is cloudy that is usually a good sign.
    Did you test the stain with a vitamin C to see if it would remove it? Not all stains will be removed by only ascorbic acid...sometimes more involved procedures are needed.
    Jul 2006
    The interesting thing is the water isn't cloudy. I am starting to think that the stain isn't completely treatable with AA. I have ordered a stain test kit, and it is on they way. .. I guess I should have done that first.
    I am going to assume you ordered the Jack's Magic stain kit. It is a good one and the products work but they are expensive. Some of their stain treatments can acutally take weeks to complete so you might also need a jumbo bottle of POP (Pool Owner Patience)! You never did reply if you tested the stain with a vitimen C tablet? If that cleared the stain where it sat then ascorbic acid WILL work. If it didn't then you might need oxalic acid or even more drastic measures.
    Jul 2006
    Well, I don't have any vitamin C around the house.... so I can't say for sure. I did order Jack's Stain kit so we will see what it says. If it may take weeks, then I guess I will get the water back to balanced, and then tackle the stains once I know what I am dealing with.
