Roger,
If the smell from the spa occurs only when you turn it on, there may be a high concentration of chlorine built up in the spa piping, which is then gassed off with the blower is turned on.
If you can keep the pool water running even slightly through the spa without the blower, this may alleviate the problem.
Hope this helps.
Pat
