Results 1 to 8 of 8
Thread: Test results and problems
    Powegian is offline ** No working email address ** Powegian 0
    Jul 2006
    Poway, CA
    Default Re: Test results and problems
    Hi Waterbear,
    Thanks for replying. I retested my Chlorine, I am using a DPD test. I had to dilute the water using 1.8ml pool/tap water. FC was 2.5, TC was 25 after multiplying. CYA was a "guess" since the black dot disappeared about 1/2 way to 100. Do you think I need to do a complete drain/refill?Thanks again.
    duraleigh Guest
    Warren,
    Complete drains are troublesome. My thoughts would be about 60% or so. That should get your CYA down into a manageable range around 60-80. I would live with that the rest of the Summer and then, next Spring, you can lower it again if you need to.
    You chlorine numbers are still a little mixed up. FC + CC = TC. Based on your results, that would mean your CC's are 22.5....which is not correct.
    For the rest of the Summer, you need to stick with bleach for chlorination. Your CYA and Ch are so over the top you will only make it worse if you use anything else.
    I would decide how much to drain pretty quickly....the sooner you can effectively attack your water issues, the easier it will be to clear.
