Closed Thread
Results 1 to 10 of 13
Thread: pools
    Jul 2006
    Default Re: pools
    Quote Originally Posted by topnotch
    Hey there
    I am pretty good with plumbing & wiring too ...just about to put water in my pool....took a month off from work to build it...like to do things myself. ITs done but I wish I didnt....well maybe not....well....we'll see once the water goes in.
    If you do it you will need a thorough knowledge of codes if you are putting underground gas water, electric, pool lights....way more complex than I knew and I am a GC. When the rubber hits the road, the elec & plumber earn their $.
    Plan some nice weather too....
    Where I worry the most is trowling and the dig. I know it has to be right or there is a big mess.
    Where I live there are no plumbing codes(country). Besides water flows downhill,,,,right?. lol and I have some friends that will tell me code for underground electric here. I can easily do that work. As stated above, I did my own electrical and plumbing in my house I reside in.
    I think I am going to look into charges for excavating, a person that can do the troweling and a good concrete man. Those are the main areas that really have no experience in except minor things. I have at least a month off next summer so there is no excuse not to try and do it myself.
    Thanks guys. I will continue to ask questions I am sure so I can get info from You guys on good equipment
    keithw is offline Registered+ Thread Analyst keithw 0
    Default Re: pools
    Archer,
    I would consider a fiberglass pool if I were you. You can cut a deal directly with the manufacturer and save a lot of money on the shell. They supply complete digging and installation plans. The pools come already plumbed with skimmers and returns. If you are so inclined, you could even dig the hole yourself, it's really not that hard. I did mine completely including the dig. All I had to contract out was a dump truck to be there to load dirt into. Fiberglasss is more expensive for the shell than a vinyl kit but much easier to install and maintain and you'll never have to replace a liner. The digging requirements are not precise because you backfill under and around the pool with sand. All you really have to make sure of is the slope of the bottom.
    There are a number of good fiberglass pool companies who make 8ft deep pools, and you can get them in a ton of different shapes. CPC, Viking, and San Juan are well respected. I've priced the 8ft deep shells out for around 10-12k.
    the woodlands, texas.
    Default Re: pools
    Building your own pool isn't that hard if your mechanically inclined.
    Whether your in an area which has building codes or not, your most well served by adhering to them. The last thing you'd want to do is, upon sale of the property, be forced to bring the improvement into compliance because the buyers inspector found things that didn't meet code.
    I build lots of pools in unincorporated areas where there is no enforcement of building codes. These standard were adopted for your protection.
    See Ya,
    Kelly
Closed Thread
