Hi,
Well we got the ground as level as its gonna get last night. No work today due to rain.
We also have the rails set up too. I also ran the transit around to check for level again so I can sleep before we build. Next goes the plastic barrier which is 4 mil and I hope that is enough. We will cut this inside the rail once we pile the sand in the middle.
I was confused about putting plastic over the sand but I reread it and you said to "pull" the plastic over the sand then install the wall. Makes perfect sense now. Then put the plastic back to the walls again.
We will also put some barrier up the walls about 12 inches after that so that around the edges, there will be double protection as it will be double thick.
New pictures are in the book.
http://pg.photos.yahoo.com/ph/veteri...m?.dir=a97bre2
More to come.
Rhon
I have a pool and I swear I'll use it if I have to!!!
