Re: cloudy after killing algae
Allowing the Algae to settle out to the bottom and then vacuuming it is what I would say that you should do at this point. Those intex pools have sad vacuums though from the sounds of it though so I suppose that you may just have to filter it...
Thanks. Maybe I haven't given it enough time.
The intex vacuum works ok if you run around the inside of the pool to create a vortex, let all the debris settle in the middle, then run the vacuum over it to suck all the debris into the little sock.
The filter is fairly weak and cloggs up with white slime, which I assume is dead algae, and I swap filters once a day, hosing off the filter I pulled out.
I have been keeping my cover on the pool, trying to keep the chlorine loss at a minimum, plus we've been having some rain
Ph has been hard to pinpoint since it goes up every time I add bleach. it has usually registered in the low 7's. It's hard to tell with the Aqua Chem test kit. The kit doesn't give enough resolution to pinpoint exact number. It should be fine to keep me in the ballpark and keep our Intex pool sanitized.
So keep brushing, swapping filters daily, maintain chlorine levels, and this cloudiness should go away within a week or so?
I have the same problem with my intex 18x48. I have run the filter 24/7 for a week now and it has cleared slightly but still cloudy at the bottom. From reading this site I found a great recommendation for the poolbuster. I just got it today so I hope it will clear the water since the vacuum for the intex will not. I'll let you know how it works!
Shannon
Hi I would leave the cover off while shocking and keeping higher chlorine levels as some of the gunk you are killing leaves the pool as gas. it would be alright to cover it at night but it helps to let the bad stuff gas off.
Ken
You can also siphon vacuum to waste to get the fine stuff off the bottom. There are several posts in the Intex area that tell how to do this.
