I have a 22,000 gal IG with spill over spa and swim out. So take this for what its worth. Went with upgraded system. 2spd pump, 500lb sand filter and SWG. By upgrading the system I went from 1 skimmer, main drain, 2 returns in pools and 1 1/2" pipe, 1.5hp pump. To 2 skimmers, 2 main drains, 4 returns in pool and 2 1/2" pipe. Run the pump on High for 1hr then low for 8 and high for 1hr. Has worked very well so far. Pool was finished last August so still playing. I also had them add a autofill, overflow drain during construction, I did the plumbing for this. No charge for installing it in the pool wall.
Other than initial cost, I know of no problems--and LOTS of advantages. I was shocked to see that my filter (200# sand) works BETTER at low speed. The water seems to have more time to filter.
Lots quieter, too. I rarely run at full speed except when backwashing.
Re: Any Negatives on having a 2 speed pump
Svengali,
One big negative is that a 2 speed pump may not prime itself if turned on without prime while on low speed setting. This may lead to a ruined pump. There are 2 speed controllers that handle this, but to my knowledge, these are all pretty expensive.
I started a project to build my own 2 speed controller, but so far I have not finished it.
Jim
