Hi, Peggy,
Good work. Now I'm gonna' be just a little obnoxious to make a point. Since your making improvement with a Cl of 15ppm, KEEP IT THERE until your water is crystal clear. If you'll stay the course, your water will look better than it has in a long time.
Run your pump 24/7 this whole time. Watch filter pressure and backwash as necessary. You've got a lot of dead algae coming out of your pool and your filter pressure will probably go up.
