Re: Cya
Most of the people that use this forum keep some CYA in their pools. If you want to raise your CYA levels there is nothing wrong with using tabs to do it. Many people use tabs until they reach a desired CYA level and then switch to bleach. Some people keep their CYA a little low so that they can use the conveinience of tabs when they go out of town for a few days. You really don't want to let your CYA levels get to high because it inhibits the chlorine and you'll end up with algae growth and ineffective sanitization. If you switch back and forth between bleach and tabs you'll notice that the pH levels go up with bleach and down with tabs. Some people do a "balancing act" between the two by using tabs when the pH is high and bleach when it gets low. I can't recommend any of these techniques, because my pool already had high CYA when I bought the house, so I don't have first hand experience. If you're in the South you probably want a CYA of at least 30 IMHO.
22,000 gal gunite pool, 1.5 hp pump, DE filter, and dreams of a SWG.
