Results 1 to 10 of 12
Thread: Really confused on cause of haze
    N.E. TX
    Default Re: Really confused on cause of haze
    Filter is a sand filter. Maybe I need to add some DE to trap this "sediment".
    Correction to original post.
    ALK is 70
    CAL is 110
    I will go for the higher CL, but could my haze be from low ALK? Is it low because of the acid that I use to keep pH down? If so, how do I keep the pH down without affecting alkalinity so much? It may not have anything to do with it, but I just thought it would be worth mentioning.
    Thanks for the replies and keep 'em coming.
    27,000 IG Vinyl
    Aquarite SWG
    Still Learning Everyday
    mbar's Avatar
    Ashland, PA
    I don't think the haze is from the low alkalinity - it isn't very low, you want alk to be between 80 - 120. You can add baking soda to bring up the alk - it may bring up the ph a little, but that would be ok. Using baking soda will raise the alkalinity and the ph may raise just a little' - then you can add acid to take the ph down - it won't effect the alk much. When you want to raise just the ph you add borax, it won't raise the alkalinity. Hope this helps, ask any questions you may have.
    Northeast PA
    N.E. TX
    I've never had to raise the pH, I think it is because of the SWG. Is my ALK down because of all the acid I have to use? I think you are right, though, I need to raise the FC. I'm just trying to understand the relationship between pH and ALK. If I get my ALK up some, won't that help my pH not to fluctuate?
    27,000 IG Vinyl
    Aquarite SWG
    mbar's Avatar
    Ashland, PA
    Yes, if the alkalnity is stable it helps the ph to stay stable. I would just let them both alone for now, raise the chlorine, kill the rest of what is making the pool hazy, and then work on the alk and ph, they are fine for now.
    Northeast PA
    N.E. TX
    You got it! I have learned to do EXACTLY what I'm told on this forum. I added extra bleach last night to get it up to 20. I noticed this morning, it looked a LITTLE better. Big problem - I ran out of DPD reagent this morning so I don't know how much it used overnight, I added a gallon anyway. I ordered refills from Ben, but I assume his shipping log is still full. I guess I will try the dilution method. That stuff is still settling in the exact same spots. I guess I will vacuum tonight.
    27,000 IG Vinyl
    Aquarite SWG
    North Florida
    Thumbs up Re: Really confused on cause of haze
    For what it's worth, you may not have to wait for your refills for very long . I ordered refills on 7/11, they were sent out the very next day and I received them on 7/17 - also in TX. Way to go, Ben!
    Sandy
    N.E. TX
    Update - Water could be accused of being PERFECT today. I think you were right Marie, I need to shock at 20. (and I thought stains were your only specialty - hehe). I plan to keep it up there for a while until my refills get here. Will 20-25ppm damage my liner? After I bring the CL back down, I plan on maintaining pH at 7.2 and ALK at 100. Does this sound acceptable? I read somewhere that SWGs seem to be a bit more effective at a lower pH. I also noticed there was considerably less "stuff" on the bottom this morning. Makes me wonder if the "stuff" was some sort of algae that wasn't getting completely broke down. Anyway, thanks a million Marie. I hope someday to be able to help like you all do.
    Thanks again.
    27,000 IG Vinyl
    Aquarite SWG
