Sounds to me like you were draining from your skimmer, and when you got below that you were sucking air and burning up your pump.
Did you burn up your pump? I would try and verify that your pump is still good, then try and get it so your sucking from the bottom drain and not the skimmer.
I had to have my pool drained with a pump and a hose running out front to the curb.
