Re: Test results and problems
Hate to say it but a drain and refill is the first order of business to get the CYA and Calcium under control! Also Do you really have 3.5 ppm CC? That is way too high. Which type of chlorine test are you using, DPD (color comparator) or FAS-DPD (titration test). If you are using the DPD test then the results when you add the third reagent would be your TC. TC-FC=CC which would give you a CC of .5 ppm. IF you are using the FAS-DPD test then the second tritration would be CC. If you really have 3.5 ppm CC then you have never really reached 'breakpoint'. With your high CYA levels this is possible since you would need to shock to a level of about 25 ppm to achieve this. See this thread for more info
http://www.poolforum.com/pf2/showthread.php?t=365
Also, there is no way you can get an accurate reading above 100 ppm for CYA with a reagent test unless you are dilituing the sample first. I would be interested in hearing how you got your CYA reading....it sounds like it came from test strips.
