Results 1 to 10 of 10
Thread: Solar Panel Options?
    JWB is offline ** No working email address ** JWB 0
    Upland, CA.
    Default Solar Panel Options?
    Hi,
    I was wondering if anyone could give me an idea what it would cost to have a solar panel system installed? Here's my situation:
    The pool is 26,000 gallons.
    The panels would mount on a 45 degree angle tile roof that faces North.
    I have a motorized vinyl cover for night closure.
    I have no idea how many panels I might need, or what size they should be.
    Anyone care to assist me?
    Thanks,
    Jon
    Default
    I have been reseaching solar because I want to add it to my pool. Every company that I have talked to and everything I have seen on the net does not recommend aiming the panels north. (I don't think it means it won't work but it might be very ineffecient)
    duraleigh Guest
    Default
    Hi, Jon,
    Yeah, I'm no solar panel guy but I think that North-facing issue might be a deal breaker.
    Dave S.
    Dec 2005
    Orange, CA, USA.
    Default
    I had Fafco's "SunSaver" panels installed when we did our pool. Since we had a South facing roof (two story), the dealer recommeded 75% of the surface area of our pool. The panels are 4x12 and they installed 7 panels. The total cost out the door was $4000. It was very straightfoward and didn't include any trenching. Today, my pool was 81 degrees while my neighbors similar pool with the same sun exposure with no solar is at 68. What the others have said I was told as well, and that's North facing will not yield the same results.
    InfinityPools is offline ** No working email address ** InfinityPools -
    Default
    Hi heres your dilema, a 45 degree north face would need 8 to 12 panels to achieve a 15 to 20 degree change in tempature.
    It depends on what kind of product you decide on my price would be anywhere from $5,500 to $6,800 for plumbing, product and labor.
    If it were me, I would go with the hayward HP6002 a much cheaper alternative. With a 5 year warranty.
    Just my opinion: But choose what will be best for you.
    Upland, CA.
    Unhappy
    Well, I guess solar may not be the best option...thanks for the info guys. What kind of electricity costs do heat pumps incur?
    (I'll be running my central air congruently and that's an AC user!)
    Indiana.
    Default
    The problem with north facing panels is they only get enough sun in the part of the year you don't need them. When sizing the system, make sure you keep in mind that a system for year round swimming is different from a season stretcher.
    Do you have yard space to put panels on racks, or could you build a poolhouse or patio cover to put the panels on?
    Default
    Quote Originally Posted by JWB
    Well, a heat pump's effeciency depends of a lot of factors such as the outsife ambient temp, how much of a temp increase you are looking for, etc. It is also depenedant on where you live and whether you just need a season stretcher or year round heat but as a general rule of thumb a heat pump will cost more than gas or electric on initial purchase but over the years will literally pay for itself with lower operating costs. If solar is not an option for you then you should definately explore heat pumps. As for the cost to run them, realize that they are basically the same thing as your central AC unit and are sized in BTU's and have energy efficiency ratings,etc. Some of the units are even reverse cycle and can both heat and cool and can acutally work in freezing weather! (wouldn't have believed it until I saw my Aquacal Icebreaker heating the pool with an ambient air temp of 31 Degrees!)
    Best advice I can give you is to start looking and comparing and talking to as many people as you can. Find out what works well in YOUR area! Talk to some solar companies, they might be able to come up with alternative panel placement that could work for you, also!
