Re: Does a solar cover help reduce algae growth??
I wouldn't be without my solar blanket/cover. I bought a heavy Magni-clear from Holiday Pools last year and love it. I can't say as that it would reduce algae growth, but it definitely helps keep the temperature of the water stable overnight, and helps keep your chemicals from evaporating too. The biggest asset to me, being surrounded by trees, is that it helps keep my pool clean! Everyone who swims in my pool - and we share it with a lot of our friends and family, can't get over how clean it is! The debris that collects on top of the solar blanket blows off, or it drops off outside and inside of the pool when I roll the cover up, then most of it floats right into my skimmer. I have an awesome setup for my reel, though - off the end of my pool. There are other threads about reels you can check out - many others on the forum use the same method I do. If my cover gets excessively dirty... I roll it up off my pool onto my reel, then unroll it onto the ground on the outside of my pool. As I roll it back up onto my reel I rinse it with a hose with a good sprayer on it. All the debris goes onto the ground and the blanket is nice and clean again. Last winter I left it rolled up on my reel and it wintered just fine.
It is recommended to uncover your pool for at least 2 hours a day, though. I would leave it off longer if you are fighting combined chlorine over .5. I'll admit, though, if we don't swim, I don't take my cover off and have not had any problems. We use our pool almost everyday, though, unless the weather is bad... We get some pretty hefty winds here in NE, and I've never had problems with it blowing off. It's a heavier blanket, though- is stiffer, rolls up and pulls off the reel back onto the pool easily. Can't imagine being without it!
Sincerely,
Donya (huskerfan)
