Results 1 to 10 of 15
Thread: Need advice about TA in new pool
    Default Re: Need advice about TA in new pool
    Quote Originally Posted by jstonemo
    It is vinyl. I didn't test for hardness because it is a vinyl pool. I will do it if someone here thinks it would be important to know the numbers.
    Nope, it's not important. So long as the water isn't touching any plaster or grout, you not only don't need calcium, but you can stay with the alkalinity and pH that you are at now. If you find that your pH swings more than you want from the addition of chlorine, you can always bump up your TA a little (perhaps to 80). If you wanted to go higher than that in TA, you may need to set your pH target higher as well. As it is for now, if you're happy and the pool's happy, enjoy!
    Just be sure to keep your chlorine at the minimum levels recommended by Ben's Best Guess CYA chart which it looks like you are doing.
    Richard
    Carterville,IL
    I am dealing with guidance from an INground pool dealer for my 30' AG. As I read these posts I assume to think hardness is not an issue with ag vinyl lined pools????? She is taking baby steps w/ me to get my water to"level". I started out w/ 6 lb of stabilizer and added some smart sticks. From there I was told to add baking soda till she tested my TA to be about 110. We shocked w/ one lb of burn out extreme, then she sold me a 23$ bucket of baquacil brand calcium hardner stuff to increase water hardness.( she said we have too soft of water around here) From here I will take another sample in on thursday (6 days from now) and go from there. She'll probably tell me to put in the algaecide (cause that's the one thing so far I have NOT been told to add) and to keep my sticks going. The pump stays on 24/7 to make me feel better about the clarity of the water. What do you guys think about this hardness increaser. I have a 16lb bucket and am adding 4lb @ a.m and p.m. per day.
    So far I have felt confident in her suggestions, especially cause she saved me hundreds of dollars from my pool purchase place who wanted to sell me tons of bioguard chem's based on my initial "fill" testing that they did. I felt as if they were trying to make their $$ off me by having me dump over 100 lbs of chemicals in at one time?????????????????????????????
    You are right, you don't need the calcium hardness increaser in a vinyl pool. It sounds like you are doing a bunch of stuff that isn't necessary. I would not put in the algaecide until we know what it is. There are a lot of algaecides out there that make your water foamy, add copper, etc. that we don't like to use. What are smart sticks?
    Post current water testing results taken with a drops based kit and let somebody here take a look at them for better advice. Most of us use the kit Ben sells at his www.poolsolutions.com website, but at the very least buy the 5-way drops based kit at Walmart for about $15 and test yourself.
    Post back with results before you add anything else.
    I believe that smart stix are a different shape of trichlor pucks...
    Wouldn't be a bad idea to get a current CYA and pH level.
    Carterville,IL
    On July 28th my readings were as follows/
    The FC----1.2
    The ph---7.4
    The TA---110
    Smart Sticks are a form of trichlor...made by bioguard. The calcium hardner is done/ I won't buy it again though considering she is an nground pool operator and the one in my backyard is an AG vinyl lined.
    I don't know where to go from here ........my water looks marvelous, I just want to keep it that way. I was wondering about the algaecide. It's bioguard step 3. It's active ingredients are
    Alkyls and dimethyl benzyl ammonium chloride. It says its a once a week application. I have had water in my pool now for 9 days and so far it is nice nice nice. So any suggestions ??? Thanks
    Carterville,IL
    yes, it is brand newly filled. What is the cya????? I have 6 way and 4 way strips but the lady who has been helping me uses drops. She'll test again this thursday and we'll see what she has me add...???? I'll consult here before I buy/add anything. if you look on the thread on backfilling an AG pool....my pool photo is on there.
    So when do I need to add algaecide??? Only if we see algae????
