Re: Metal Treatment Here I go!
Now is fine to do the treatment if you opt to do it with AA.
You can swim after the treatment, but the water may be cloudy. You could start Thursday and have your water clearing up by Sat/Sun if all goes well.
To do the AA treatment:
Bring chlorine down to 0
Use 1/2 to 1 lb AA per 10k pool water - You may need 3 pounds
Get AA from here: http://www.chemistrystore.com/Ascorbic_Acid.htm or some people can find it locally, I can't though so I order.
Do not dilute the AA. Go around the edge of your pool and drop it down the sides.. or if you can sprinkle it directly on the floor of your pool where there are stains.
You will need a quart per 10k gallons pool water (3 quarts for you) of sequestering agent like pool magent, or jack's magic - I use Aqua Chem metal, scale and stain treat from WalMart. Add the sequestering agent about a 1/2 hour after you add the AA.
You HAVE to drop your chlorine levels for the AA to work. Otherwise the AA will just eat up your Cl and not the stains. You also need to bring yoru Ph down to 7.2 for this treatment. Actually, bringing your Ph down may work on it's own to lift the stains.
4) Could I just use Vitamin C rigged up in a stocking & pole & rid the pool of the stains w/o doing anything else? It would take longer yet I could take my time & lose no pool time?
That may be entirely possible.
Good luck. Mbar and Waterbear have shared so much information with me here. I'm happy to pass along what I know.
