Thread: My first test results
    Jul 2006
    Default My first test results
    FC 3.6
    CC 0.2
    Ph 7.2
    CYA 50-60
    Calcium 140
    This is a 3 week old gunite pool (25K gallons). I had been operating off a Guardex 4-way test and adjusting chlorine and Ph based on that until my K-2006 came today, and I think all is well. Sounds like I might want to lower CYA a bit next spring after we lower water levels for winter prep and then refill in spring.
    Any other thoughts?
    Default Re: My first test results
    What's your Total Alkalinity (TA)?
    Jul 2006
    Sorry, forget to type that. TA is 80
    duraleigh Guest
    Nice numbers...good work! If you don't have a SWG, you might consider chlorinating with Cal Hypo. It's a nice slow way to bring your Calcium up a bit (maybe 250ppm) and it's a convenient chlorinator. Happy Swimming!
    Jul 2006
    What is SWG? I am guessing that it is salt water chlorine generator; if so, I don't have one.
    I will look into Cal Hypo tomorrow. Is that a brand name or a generic chemical?
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    trauh ,
    Its calcium hypochlorite.. any brand will do , just DONT get the stuff that has stabilizer (cyanuric acid ) in it,, you already have enough
    Jul 2006
    I found cal-hypo in the form of HTH. It looks like HTH shock comes in 1 pound bags (around 60% chlorine). Using bleachcalc it says that I need to use 0.4 gallon of 6% bleach to raise chorline 1 ppm. How much HTH does that equate to?
    Also, can I use HTH tablets in the skimmer as a way to maintain the pool when I travel for 4 or 5 days?
  1. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  2. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  3. First test results
    By poolbee in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:27 PM
  4. First Test Results
    By Cutter in forum DPD-FAS based testing
    Last Post: 06-14-2006, 08:30 PM
  5. first test results
    By jazzbone in forum DPD-FAS based testing
    Last Post: 05-26-2006, 04:19 PM
