Thread: My first test results
    Jul 2006
    Default Re: My first test results
    Sorry, forget to type that. TA is 80
    duraleigh Guest
    Nice numbers...good work! If you don't have a SWG, you might consider chlorinating with Cal Hypo. It's a nice slow way to bring your Calcium up a bit (maybe 250ppm) and it's a convenient chlorinator. Happy Swimming!
    Jul 2006
    What is SWG? I am guessing that it is salt water chlorine generator; if so, I don't have one.
    I will look into Cal Hypo tomorrow. Is that a brand name or a generic chemical?
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    trauh ,
    Its calcium hypochlorite.. any brand will do , just DONT get the stuff that has stabilizer (cyanuric acid ) in it,, you already have enough
    Jul 2006
    I found cal-hypo in the form of HTH. It looks like HTH shock comes in 1 pound bags (around 60% chlorine). Using bleachcalc it says that I need to use 0.4 gallon of 6% bleach to raise chorline 1 ppm. How much HTH does that equate to?
    Also, can I use HTH tablets in the skimmer as a way to maintain the pool when I travel for 4 or 5 days?
