Results 1 to 10 of 10
Thread: Need to add calcium
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default Need to add calcium
    I was doing work for an ex-neighbor today. First time I had been to their house in a couple years.
    Last year they had a gunite pool installed and he was complaining the plaster was geting rough and mottled looking. He had gotten the Pool Company, 20 minute tutorial and a package of test strips.
    I went home and got my test kit,
    Cl 3
    ph 7.2
    Alk 100
    Cya 90
    Hardness 0 !!!!
    I know he needs to add calcium chloride. But not sure best source, I seem to recall "Ice Melt" was acceptable. Just want to verify or get recommendation for alternate or preferrable source.
    North Florida
    Default Re: Need to add calcium
    I'm not sure how to post links to a past post, but you can go to a post entitled, "Calcium" on this forum with a date of 7/1/06 and you'll see the whole discussion of DowFlake as a calcium increaser.
    You might want to encourage your ex-neighbor to check out this forum as it appears his/her chlorine levels are not adequate for a CYA level of 90. You did your ex-neighbor a real favor testing the water for them and giving them some direction .
    Sandy
    Here is a link to the Dow Chemical website on their products for pool and spa use...Dowflake is the most easily obtained since it is used as a de-icer.
    http://www.dow.com/calcium/app/poolspa.htm
    nj, usa.
    Managed to find 50 pound bags of Calcium Choride Flakes for $14.00 at a masonry supply.
    Thought that was reasonably priced !
    nj, usa.
    Ok, I am a bit confused now, so I am in need of the wisdom of the many !
    DId the following to 38000 gallon gunite pool:
    7-26 Checked pool, no hardness reading, just turned sample a little yellowish
    7-29 Added 50 pounds of Calcium Chloride flakes
    7-31 Checked and still getting only a little yellow in sample
    8-1 Added 100 more pounds of Calcium Choride flakes
    8-3 Checked and got a nice reddish/purple in sample, tested out at 600 on Hardness
    This was a bit high, but Cya is 90 -100 anyway, so figured drain and refilling in a couple weeks would take care of both problems
    8-22 Stopped by to check pool and again reading no hardness, test turns a little yellowish not red/purple at all.
    Can anyone tell me what happened ?
    Did the plaster reabsorb the Calcium?
    Quote Originally Posted by haze_1956
    What test kit are you using....The aquachem 6 way has an issue with the calcium hardness test that has been discussed previously in the forum....sounds like the one you are using since you said you got a yellow color
  1. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  2. Calcium = 650!
    By jman311 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-24-2006, 11:48 PM
  3. How much calcium in calcium-based shock?
    By cleancloths in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2006, 04:58 PM
  4. Calcium and SWC's
    By jacthiele in forum Dealing with Alkalinity and Calcium
    Last Post: 05-24-2006, 01:53 AM
  5. Low calcium
    By robertopod in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2006, 12:49 AM
