Results 1 to 9 of 9
Thread: Chlorease help
    Jacksonville, Fl
    Question Chlorease help
    We are using a Chlorease SWG on our AG pool. The cell is CONSTANTLY getting build up! We clean it, it works great and then again, it stops working and it's covered in build up. This seems to be an on-going problem. What am I doing wrong? I hope this is not normal since it's a pain in the butt
    Tricia
    24" Round Artesian Echo Canyan
    Chlorease
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Re: Chlorease help
    Tricia,
    Welcome to the forum.
    What exactly is the buildup? Is it scale or something else?
    A complete set of numbers would help us to help you.
    Pat
    20,000 Gallon IG Diamond Brite pool, 1.5 HP Sta-Rite pump, Hayward Microclear DE3600 filter, Favco solar panels, Poolpilot DIG-220 with SC-48 cell.
    + SWCG OPERATION thread here: http://www.poolforum.com/pf2/showthread.php?t=1226
    + SWCG Running Costs post here: http://www.poolforum.com/pf2/showthread.php?t=316
    + Effective Stabilizer addition post here: http://www.poolforum.com/pf2/showthread.php?p=6645
    Jacksonville, Fl
    The buildup is white cakey/chalky stuff.
    I'll get you some numbers tomorrow!
    Tricia
    Jacksonville, Fl
    OK, got numbers last weekend, just getting a chance to post them.
    Total Chlorine:2.5
    PH:7.6
    Total Alkalinity:150
    Total Hardness:340
    Stabilizer:40
    Phosphates:0
    Is there anything wrong here? Why is the Chlorease staying caked up with white stuff?
    Tricia
    waterbear's Avatar
    St. Augustine, Fl
    Would it be possible to get a calcium hardness reading? It would be a bit more valuable. I would suggest lowering your TA down to around 100 ppm. this should help with the scale buildup. Also, never let your pH go above 7.6. It might be better to keep it around 7.4 all the time.
    Ft Lauderdale, Fl
    I don't believe that the Chlorease is a self cleaning system, at least reading through the owners manual does not mention a self cleaning feature. This means you're at the mercy of maintaining balanced water, according to the saturation index. If not, you'll experience the scaling condition that you have. As Waterbear recommended, lower your Total Alkalinity to about 100 ppm, and maintain a lower pH to extend the period between manual acid washing of your cell.
    Sean Assam
    Jul 2006
    Tricia,
    Have you gotten a handle on the buildup problem? I saw this unit at the Pool Store recently and it caught my interest.
    How often were you having to clean the Chlorease? weekly? monthly?
    I'm sure others as well as myself would appreciate a follow up.
    TIA,
