I have two filters. I have A Dynaflo 1 Hp two-speed pump hooked up to a Hayward 300 lb. sand filter with 300 lbs of filter sand from Leslie's, and then it goes to a Pentair 150 cartridge filter and then to the pool. Even on low speed right back to the pool I have tremendous flow.
I have it hooked up to ten 2' x 20' solar panels on top of our two story house and on high speed it has great pressure. You can see the water current going way out toward the middle of the pool. On low speed, it does not have enough pressure to to go up two stories, but it didn't when I had it only hooked up to the cartridge filter. I leave it on low speed during the night and high speed when I am using the solar panels.
I bought the Hayward S224T used on ebay for $ 124 including freight. It looks brand new. I plumbed everything with 1 1/2" PVC. It works great.
My pool is crystal clear.
Aranon
