Thread: Too Big Of Filter???
    IL.
    Default Re: Too Big Of Filter???
    I think it's only a problem when the pump is too big for the filter. If they are matched, at worst you will probably just turn over your pool very fast, which isn't a bad thing, you get to run the pump for shorter times.
    As long as you can get fittings to match up to your pool, I would use it.
    What a great buy
    Morris, IL
    I would also go for it, why would you regret a faster turnover? The pool store probably just wants you to toss it and buy a new pool from them, with a new pump and filter that is specifically matched to the pool. You got a bargain I would say and for what it would cost to give it a go it would be worth a shot.
    Which Intex? Hard frame or EasySet Donut?
    The biggest problems I see are:
    First, as mentioned, if the filter is too small for the pump (or the pump is too big for the filter--same thing). In that case you may be able to get a reduced-flow impeller for the pump, which would be the cheapest solution--You got a BIG margin on a $5 pump&filter!
    The second problem is that most filters are 1.5" plumbed, and most Intex pools are 1.25" fitted--and you cannot increase the size. This mean that you'll need to step-down in fittings to 1.25" at some point, which will increase pressure and may damage the pool at that point. ANOTHER good reason for the reduced-flow impeller...
    But once you have that solved, hook up a solar panel and you'll have a HUGE hot tub, complete with jet!
  1. Sand filter vs cartridge type filter
    By stevens23 in forum Pool Equipment & Operations
    Last Post: 07-12-2012, 07:54 AM
  2. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  3. Help! Switching out 1985 cart filter to sand filter
    By JLICHTY in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 11:09 AM
  4. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  5. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
