Results 1 to 9 of 9
Thread: conversion
    bwalsh1 is offline ** No working email address ** bwalsh1 0
    Jul 2006
    Default conversion
    I have read every page of everythread in this section and I must be blind. I cannot find anywhere the step by step instruction for switching a baquacil pool to chlorine or BBB. I have read "taking te Plunge" twice and still cannot find it. Can anyone direct me where to find the step by step instructions for the conversion.
    15X26 Vinyl above ground 52"
    Northern Kentucky
    Default Re: conversion
    Taking the Plunge does not list the steps out concisely, but rather tells what was done during this conversion, with many comments in between.
    Basically, from what I have read, a good summary is this:
    1. get your chlorine up to 15ppm using bleach (lots of it!) and keep it there.
    2. Test several times a day to ensure you are keeping 15 ppm chlorine levels. Use a drops based test, (Ben's kit, Taylor, or HTH 6-way) and dilute with distilled water if necessary to read the test. Here is CarlD's shot glass method for diluting your sample http://www.poolforum.com/pf2/showthr...?t=4592&page=2
    3. Run your filter 24/7 and backwash as needed.
    4. When your conversion is complete, change the sand in your filter (if you have a sand filter ... I do not know about cartridge or DE
    Your water will go through many shades of green and orange as the Baqua is being consumed by the chlorine.
    ...Mods or anyone more knowledgeable than I, feel free to amend my brief summary if I did not get it quite right!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    BAsically, you have it right--I would only add that you need to get to the 15 ppm and KEEP IT THERE until the Cl no longer drops overnight. At that point your conversion is complete, and you need to change your filter media, then add stabilizer and start balancing your water.
    As Grace said, be prepared for some really strange colors in your pool before it's all over with!
    Northern Kentucky
    Thanks Janet! I guess it IS pretty important to know WHEN the conversion is complete!
    ~Grace
    Jul 2006
    Thanks for all of the help and input so far. I am sorry to be a pest but like everyone else on this great site I am a little nervous. Can I use any kind of bleach and will chlorine work in its place?? Also how many gallons at 1 time should I be adding to this ?? Not total I know but do I want to try 5 gallons at a time. Thanks. I am not afraid of the strange colors you should see what color the Baq has it at now which is my last straw after only a year and why I am finally ready to convert. Thanks again for any and all guidance.
    Northern Kentucky
    Quote Originally Posted by bwalsh1
    I am a little nervous to answer, as it seems like I am always forgetting some bit of info, but so you don't have to wait long for an answer, I will post what I know!
    You should use plain, unscented regular (5.25%) or ultra (6%) bleach, or liquid chlorine (usually 10% or 12.5%. read http://www.poolforum.com/pf2/showthread.php?t=4585 for more info on that.
    As many as needed to get you to 15ppm. The Baqua will eat up the bleach very quickly at first.
    Good luck with your conversion!
    ~Grace
