Results 1 to 10 of 12
Thread: DPD powder experiment
    Honesdale PA
    Default Re: DPD powder experiment
    I think the 'bad' powder is obvious. Form your own opinion. Best I could do for lighting and a gray scale without fussing too much but it is white to black. I know...I've got to get a life. But...this is fun stuff.
    Attachment 450
    Earlier I indicated that I kept a container of the dpd powder for over one year before degradation. The stuff I have now I bought two years ago and lasted two full seasons, with what appear to be accurate results (add 5 ppm of bleach, get a 5 ppm rise in measurement). I keep it in a dry location on the bottom floor of the house. I do not put my test vials in the kit container so there is no moisture locked in. I am looking forward to Al's report on the stuff he keeps in the fridge.
    Honesdale PA
    A final followup on the original experiment. The caked, dark DPD powder that was used in the original test was now a hard chunky lump that had to be ground up. Yesterday did a 25 ml sample test of that vs. good powder and the results were the same at FC=1.0 Today, after bringing up the FC, both measurements were 3.6 So.....looks like the DPD powder is pretty stable even though it looks pretty bad. I certainly don't recommend letting the powder get this bad but some dark gray discoleration should be nothing to worry about.
    Exclamation Re: DPD powder experiment
    Thanks for the experiment and the results !!!
    Huffman, Tx
    I have a PS233 kit, but did not use it this year. I am building a pool now and am curious what will still be good in it. I know the DPD powder is bad, but what is the shelf life on the rest of it?
    Honesdale PA
    Don't be too sure about the powder. May be perfectly good considering what I found in the experiment. I'm not sure of the shelf life of the individual components but I do keep bulk chems in the fridge and only open them to refill smaller bottles. Under these conditions they should keep almost indefinitely. Certainly you'll get a couple seasons out of them. Just keep them cool and out of the sun.
