Re: Polaris booster pump rebuild
My Polaris booster pump had been on the failing edge for about 1 year and finally seized up. Apparently a seal began to leak and simply rusted/corroded the bearings, motor, and electronics. I was never really impressed with this pump anyway and it was always noisy. I simply purchased a Hayward 5060 booster off e-bay (new in box) and replaced the pump. It took me about an hour, very easy. I could do it in 20 minutes, now. The Hayward is still noisy but it sounds a lot better than the Polaris pump did and actually sounds normal.
For about $170.00, I recommend replacing the pump.
