Results 1 to 10 of 19
Thread: I hate mustard algae
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    Default I hate mustard algae
    I'm so pleased to find some help with my pool. I've about given up trying all the various products from the pool stores.
    Anyway, my pool is inground, 15,000 gallons. I have used a 3" tablet chlorinator since I bought the house with the pool. I took a water sample in for testing, yesterday after using a quart of Leslies copper algae control. I shocked it then circulated for 2 hours and let it sit for 36 hours before back flushing, vaccuming to waste. I was so disappointed to find the mustard algae returned overnight. It's about as bad as before I vaccumed it out.
    Here are the testing results:
    FC - 10+
    TAC -10+
    ph - 7.2
    TA - 260
    Calcium Hardness 500
    CYA 150
    They told me to add a 1/2 gal of muratic acid and test again. I added it this morning, so tomorrow I was going to take a sample in again.
    I was pretty clear of algae until about 3 weeks ago when we got a midnight rain, I have a power cover, and usually close it to keep the rainwater out.
    Until my test kit gets here, I have a test kit that I bought from one of the pool stores.
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Default Re: I hate mustard algae
    My pool has been Baquacil based summers previous to this one; my past problems have been more with white mold rather than mustard algae. However, I converted to chlorine this year and got lazy with chemical maintenance recently, and have had what appear to be mustard algae problems like what you describe. I would vacuum it and it would be as bad one or two days later.
    My solution was to keep the pool at chlorine shock level for about three days and after that, making sure that my chlorine stays at an acceptable level based on my cya. Initially, I shocked it for one day, and the problems came back, so a few days later, I went through the second and longer "shock" process. I haven't had the algae problem now for about two weeks. I plan on shocking about once every two weeks for preventative measures. I'm using bleach from the store.
    Also, I used a bottle of polyquat algaecide - I'm not using the copper based algaecide, there have been discussions against using it on this forum, if I recall correctly. Do a search on polyquat on this forum for specifics. Lowe's, Home Depot, and Tom Thumb supermarkets carry it in the Dallas area.
    Read these articles, if you have not:
    http://www.poolforum.com/pf2/showthread.php?t=365
    http://www.poolforum.com/pf2/showthread.php?t=1113
    and read as many posts as you can. If you don't already know, one thing you will find out if you keep reading, is that your cya is high and the tablets will keep adding to it. I'm having a different problem, I don't use tablets - bleach only - my cya is constant and low, so my chlorine levels go down during the day, hence the problems that I'm having if I slip up on chemical maintenance.
    According to the best guess cya chart in the first link above, an FC of 10 is acceptable for your pool based on your cya level - but you would need to bring the FC to 25 for it to be at shock level.
    Usually, I pour a bottle or two of bleach in my pool if I know its going to rain and my chlorine levels are on the low end of where they should be, and I haven't had any problems with rain.
    Hope this helps for starters ....
    Jul 2006
    Wichita, KS
    This was the only time I used the copper based algaecide, and my last. I've been using some that I bought from Sam's Club that the main ingrediant is diemethyl benzol chloride (I read it, but doubt if I spelled to correct). Prior to that was the Bioguard algaecide and Banish. I'm not satisfied with any of the products since I can't keep the algae out of my pool.
    According to the bleach calculator, I should add 2-1/2 gallons to raise my FC over 20ppm.
    Mandeville, LA, USA.
    topless,
    According to the Best Guess table, for your level of CYA (150 ppm according to your first post) you need to get the chlorine to 25 ppm to shock. You'll need to keep it at that level until the algae is gone and the water will keep the same level of free chlorine overnight.
    Testing several times a day and adding bleach to return the chlorine to shock level will give you the best results. At a minimum, test and chlorinate in the morning and evening but three times a day will probably get this problem cleared up more quickly.
    Best of luck.
    Jul 2006
    Wichita, KS
    Thanks for the help. Unfortunately my start is delayed by rain today. I've got 8 gallons of bleach and my Bioguard test kit all ready to go, but I closed the cover to keep the rainwater out. It's supposed to stop by tomorrow.
    Sanford, FL
    Also you need to brush the pool daily.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    Wichita, KS
    I'm hoping my 234 test kit comes today. I've been using my standard test kit, but it's so limited.
    I recalculated my pool volume and it's more than I thought. It's a semi-kidney shaped gunite, but it's volume is 18,000+.
    So far I've used 8 gallons of bleach since Sat., vaccumed to waste 1 time, and brushed at least 2-3 times per day. I've run my Polaris after brushing, to pick up dead bugs and tree debris from the pool bottom. As soon as I switch back to the side jets, I get foam. I've had foam ever since I put in the last algaecide about 2 weeks ago. It very strange, it comes and goes. At times it almost covers the entire pool, other times it's completely gone.
    I'm about ready to just drain down the pool 2/3rds and start over. Maybe that way I can get the CYA level down enough to get the chlorine to work.
    It appears my FC is over 10ppm, about the same as my TC. ph is still 7.2, but I'm not sure about anything else until the 234 test kit comes.
    duraleigh Guest
    Draining 2/3 of your pool, if water is cheap, is a good option. You will dilute all the products that have been tossed in the pool, get your CYA to a manageable level, and reduce your calcium which is fairly high.
    If you choose this, coincide it with the arrival of Ben's kit. You're gonna' be amazed at how suddenly accurate and precise you'll be. You will have your water manageable from the start and you'll be able to keep it there.
    Jul 2006
    Wichita, KS
    I needed a part for my Polaris, so I took a water sample in to be tested. The guy stuck in a test strip and said the chlorine was too high and would throw off all the other tests. So, I guess I'm done until I get my 234 kit.
    Jul 2006
    Wichita, KS
    It's now been 2 weeks since I ordered (and paid for) the 234 test kit. I still don't have it so I can't get some of my readings.
    Last test I did:
    FCL - 4 ppm
    TCL - 4 ppm
    ph - 7.2
    The algae is gone completely, however I still have something strange happening. The pool is crystal clear, but debris on the bottom, circulating the side jets. I run the Polaris, it stays clear, debris is picked up. When I shut the pump off and switch the valve back to the side jets, it spews out white stuff that ends up as foam on the top of the water. I've backflushed and rinsed several hundred gallons (6"-8" of water level) and it still is foaming. It takes about 24 hours to dissipate. I haven't put anything but water in the pool for 2 weeks and before that only bleach. I can't figure out why it's doing this. It has done this 3-4 times in the last 2 weeks.
  1. Mustard Algae
    By AndreaA in forum Dealing with Algae & Slime
    Last Post: 06-11-2011, 12:18 PM
  2. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  3. Green algae? Mustard algae?
  4. Mustard Algae???
    By Jaybird70 in forum Dealing with Algae & Slime
    Last Post: 11-03-2006, 11:20 PM
  5. Mustard Algae-PLEASE HELP!!!!
    By CUTURHAIR in forum Dealing with Algae & Slime
    Last Post: 06-01-2006, 08:29 AM
