Re: I hate mustard algae
My pool has been Baquacil based summers previous to this one; my past problems have been more with white mold rather than mustard algae. However, I converted to chlorine this year and got lazy with chemical maintenance recently, and have had what appear to be mustard algae problems like what you describe. I would vacuum it and it would be as bad one or two days later.
My solution was to keep the pool at chlorine shock level for about three days and after that, making sure that my chlorine stays at an acceptable level based on my cya. Initially, I shocked it for one day, and the problems came back, so a few days later, I went through the second and longer "shock" process. I haven't had the algae problem now for about two weeks. I plan on shocking about once every two weeks for preventative measures. I'm using bleach from the store.
Also, I used a bottle of polyquat algaecide - I'm not using the copper based algaecide, there have been discussions against using it on this forum, if I recall correctly. Do a search on polyquat on this forum for specifics. Lowe's, Home Depot, and Tom Thumb supermarkets carry it in the Dallas area.
Read these articles, if you have not:
http://www.poolforum.com/pf2/showthread.php?t=365
http://www.poolforum.com/pf2/showthread.php?t=1113
and read as many posts as you can. If you don't already know, one thing you will find out if you keep reading, is that your cya is high and the tablets will keep adding to it. I'm having a different problem, I don't use tablets - bleach only - my cya is constant and low, so my chlorine levels go down during the day, hence the problems that I'm having if I slip up on chemical maintenance.
According to the best guess cya chart in the first link above, an FC of 10 is acceptable for your pool based on your cya level - but you would need to bring the FC to 25 for it to be at shock level.
Usually, I pour a bottle or two of bleach in my pool if I know its going to rain and my chlorine levels are on the low end of where they should be, and I haven't had any problems with rain.
Hope this helps for starters ....
