Re: anyone have any experience with the Skim Shark?
Well I was able to complete the installation today. I need to correct a statement I made earlier about the fittings that came with the PoolSkim. As it turns out it DID COME with all the right fittings. My three year old daughter managed to get to the package before I did. When I got home from work I found the box open. I found the missing fitting in her room while picking up toys today.
Anyway I'm pleased to say that the PoolSkim works as advertised. We have a 33' round AGP rated at 26000 gallons. It does require some adjustments to the placement and angle of the fittings until you get everything nice and level. I have a 1.5 HP 2 speed pump with two returns. Water pressure between the returns is controlled by a 3 way valve. The first return is for an Aqualumintor with fountain. The second feeds into the standard pool return. On low speed I had to kill the flow to the fountain on the aqualuminator to provide enough water pressure for the PoolSkim. On high speed water pressure was more then enough to run both returns.
It reminds me of a miniature toilet bowl the way it swallows up everything in site. It did not have any problems with insects, leaves, sticks, pollen or any other debris floating on the pool surface. It was able to maintain a nice gentle flow of water to keep things moving towards the opening.
All in all very happy with the product. Highly recommended.
33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
Aqualuminator with Fountain -- Solar Pool Lights
Pool Pictures at the link below
http://community.webshots.com/album/548241672nKeuyR
