Thread: Pool light problem
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Default Re: Pool light problem
    Is it 120 or 12 volt?
    Some people have hobbies.....I have a pool.
    San Antonio, TX, USA.
    Quote Originally Posted by Tredge
    It is 120 volt.
    DerrikM
    Wisconsin
    That rules out a faulty transformer....
    I dont believe there is any kind of heat sensor in those lamps.
    Sometimes electrical equipment can become naturally sensitive to heat and you may have a bad solder connection in the light housing.
    Check all connections and I would try to elliminate the GFCI as a source just in case. The last resort would be to replace the light housing.
    Since it happens every time it should be fairly easy to narrow down the source.
