Thread: Pool light problem
    San Antonio, TX, USA.
    Question Pool light problem
    My pool light has suddenly developed a mind of it's own. I have 500 watt Pentair incandesent light fixture. Replaced a burned out bulb about 2 years ago. Don't use it very much, probably about 50 hours per season.
    About a week ago I turned it on and 10 or 15 minutes later it went out by itself. I went to the switch and flipped it a couple of times, still no light. After 30 minutes or so I tried to switch it back on and it worked. Ever since that first time it's been happening every time I use it.
    It is on a GFC circuit, but it never trips. Is there some sort of temp sensor that might be turning it off because of over heating? If so, why would it all of a sudden be overheating?
    I've been considering installing a SAM light, but was hoping to put it off til next year. So, any help would be appreciated.
    DerrikM
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Default Re: Pool light problem
    Is it 120 or 12 volt?
    Some people have hobbies.....I have a pool.
    Quote Originally Posted by Tredge
    It is 120 volt.
    DerrikM
    Wisconsin
    That rules out a faulty transformer....
    I dont believe there is any kind of heat sensor in those lamps.
    Sometimes electrical equipment can become naturally sensitive to heat and you may have a bad solder connection in the light housing.
    Check all connections and I would try to elliminate the GFCI as a source just in case. The last resort would be to replace the light housing.
    Since it happens every time it should be fairly easy to narrow down the source.
