Hi poolpilot, and welcome to the forum.
The best thing you did was to change to bleach from 3" GLB pucks. They are the reason your CYA is so high. Unfortunately at 225 ppm, it is not going to come down in a hurry.
Replacing half your water seems the only option at this stage, and should take care of the CYA and CH. You are correct in not using well water to refill, unless you have filters to remove iron and copper, and calcium hardness.
The pitting you mention will have come from the low pH initially. What type of bolts do you have for the ladder? They should be stainless steel.
Carry on using the BBB method. It will help you more than you think. Have fun and keep us posted.
Pat
