waterbear (Evan),
I ran through some numbers on my spreadsheet assuming certain levels in your salt pool with borates and low TA. If I put in a pH of 7.5, TA of 70, CYA of 75 (for your SWG), CH of 300, TDS of 3200 (or salt of about 3000), 50 ppm Borates (Boron), and a temp of 85F, then this gives me a carbonate alkalinity of only 39 and a calcite saturation index of -0.47 (pool-store Langelier is -0.39). Now I know we don't give much credence to these indices and problems aren't normally seen until around +/-0.7 or even +/-1.0, but even so, the exceptionally low carbonate alkalinity in your pool plus the high salt level make the water more corrosive.
I just wanted you to know this and to be on the lookout for any signs of such corrosion, namely any dissolving or pitting of plaster/gunite/grout. If you notice your calcium hardness increasing (or not decreasing as much as it normally does, if it decreases from backwashing), then that would be a sure sign of trouble.
Assuming your CYA is high for the SWG (at 75 ppm), then a TA of 100 (carbonate alkalinity 69 and relative outgas rate 6.0) shouldn't outgas that much carbon dioxide, though it would be at about double the rate of a TA of 70 (carbonate alkalinity 39 and relative outgas rate 2.9). A TA of 100 would bring the "index" to -0.22 while also increasing the CH to 500 would bring the index to -0.01.
Richard
